Thread: False Initial PH reading
    Orland Park, Il
    17
    I use the Taylor K-2006 test kit and have noticed that I frequently get an initial false PH reading well below what it measures the second (or third ) time. I usually measure my Chlorine first so I tried to change it by measuring PH first, but I still get the initial false reading. I always rinse between tests and my Chlorine levels are usually between 3 and 5 so I don't think this contributes to the initial low ph reading. Any one else have this issue?
    Thanks
    16 x 32 ABG
    22,550
    Re: False Initial PH reading
    Nover had a problem with the pH test like that unless I didn't rinse the vials in pool water before running the test. Rinsing it in tap or other water will affect the test the first time.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    If you are using the lid make sure you rinse that too. I used to get the false reading after doing the chlorine check and it was because I didn't rinse the lid.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
