Results 1 to 8 of 8
Thread: Refit Gardiner Maine
    mcaron74's Avatar
    Jul 2011
    gardiner maine
    20
    I have just started replacing the liner in my pool. I am going to do my best to document it here over time and take lots of pics.
    My Pool: Indoor 20x40 Lazy L, sand filter
    mcaron74's Avatar
    Jul 2011
    gardiner maine
    20
    Re: Refit Gardiner Maine
    I decided i cant afford the prices the pool shops want to replace the liner, so i am going to try to do it myself(with friends) for 1/2 the cost.
    In order to acurately measure i had to pump it out, and remove the liner as it was pulling away from the edges, and i could not get an acurate measurement.
    (some photos are not as clear as ide like.....)
    mcaron74's Avatar
    Jul 2011
    gardiner maine
    20
    I have now measured and am going to be submiting for a quote at intheswim.com.... Have any of you used other places for a liner? Any suggestions or things i should consider when chosing one?
    mcaron74's Avatar
    Jul 2011
    gardiner maine
    20
    Here is a color/pattern I liked... http://www.pacificpools.com/vinyl-liners/core-patterns I prefer the carmel/sandstone. My wife likes the Blue sierra/crystal.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey there, welcome to the forum and thanks for sharing your project. Looks like a job, but you'll have some experienced under your belt. Really nice to have an indoor pool I bet. Especially up there! Hope to see it when you start.
    Essential Links:
    Columbus Ohio
    178
    That looks like quite an under taking!!! Good for you, I love watching these things!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    mcaron74's Avatar
    Jul 2011
    gardiner maine
    20
    So its been a while, but we finaly have the liner in. I did not do it myself because i found a pool company that was willing to diagnose the watter line issue. I had 2 skimmers and 5 return lines. they had to cut into the wall to repair one of the returns that was broken right behind the wall, and completely block another return. Ihave 4 that still function... so i am happy. The water is still a little green. (a little better than in this pic) i shocked the pool per the liner installers instructions.... seems to be at about 18ppm for about 2 days now.....i have it covered, and its indoors so no sunlight. I am going to uncover it tonight hoping to get the chlorine levels back down..... Stabaliser is almost 0 and it is reading as 0 combined chlorine.
    I seem to be loosing about 3/4 of an inch of watter a day.... so it looks like i get to play the game of find the leak as well... the liner installer did a pressure test on the lines and they are all good. He thinks its around the stairs so is going to come back tomorow with some dye..... If it is... we will have to drain it back down and try sealing it up again. Dont realy want to do that.. but i dont see what other options i have other than replace 500gallons of watter a day.
    I also picked up a 200,000 btu propane heater for $200 on craigs list (10 years old hayward h200) that we are setting up outside temporarily until we can find a permanent place. ofcourse that needed a few parts... they are supposed to be in next week.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Any update? Hate you had a leak, but hopefully it was not too bad a fix.
    Essential Links:
