Results 1 to 7 of 7
Thread: Intex Easy Set 18' filter problem
    I have an Intex Easy Set 18' pool with the 1500 gal filter pump. It's been working great up until about a week ago when I seem to have lost most of the suction. I've replaced the filter, checked the hoses and inlet\outlet valves for any obstructions, and found nothing. The skimmer is def below the water line, and if I take it off and just drop the suction hose into the water, I get very low suction as well. I've bled all of the air from the filter. My next thought was to maybe lube up the plunger valves and/or replace, but I wanted to see if there are any other suggestions out there in case the plunger valves aren't the issue. The filter is 2 years old and seems to be running fine from what I can tell.
    Thanks!
    PA Pool Mom
    18ft; 8600 gal; Round AGP; Hayward Sand Filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Intex Easy Set 18' filter problem
    Try.taking the hose off the suction barb on the pump and see if it might be clogged there. Might be hair, leaves or something pilled up on the strainer grid blocking flow.
    Essential Links:
    Is the screen in the inlet side of the pump clogged?
    Thanks guys.
    Brushpup: When you say off the suction barb, what are you referring to exactly?
    FesterW: Checked the inlet side, everything looks clear
    PA Pool Mom
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by seanf12
    Thanks guys.
    The inlet of of the pumps, where the suction hose connects to the pump body. If it is clear, are you sure it is getting proper prime?
    Essential Links:
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Do you see any small holes/ports inside the pump that have debris in them? H says they're relief ports and we use a pick/pokey thing to clean them out.
    Check the inside of the pump very carefully and clean any area that has debris at all. Even if it just looks like an access hole for a screw. H might be right about these ports being important... when he talks pump, I do not question him.
    Have you tried running the pump without the cartridge filter installed? What result does that give?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Frogabog, good call on running without a filter. As soon as I pulled the filter and ran it the suction was fantastic. I never thought to check the filter because it's only about a week old and ran fine the first day or two I was using it (and it's not dirty at all)
    I am going to pick up a new filter tomorrow and see if that helps
    Thanks everyone!
    PA Pool Mom
