Yes, now you are catching on to what this forum is all about. Maintaning a trouble free pool.
Chlorine tablets have CYA in them. CYA is a stabalizer that protects chlorine from the sun. Without CYA your chlorine level goes to zero quickly in the mid day sun.
Too much CYA makes the chlorine loose it's effectiveness. You use more and more introducing more CYA until your pool turns to a swamp.
Many people think it is normal to have to periodically drain and refill thier pool but with proper water balance it is not necessary.
Adding plain bleach to your bromine will raise the bromine level.
As for the future to properly manage a chlorine pool you need a good test kit. Test strips will not work. Without a good test kit you will be guessing what your water needs to remain clear and sanitized. Any money spent on a test kit is recouped in chemical cost savings. Your first mission is to obtain a good test kit then we can help you with a chlorine pool. Do you have salt water chlorine generators available in your area?
