Results 1 to 8 of 8
Thread: What the heck are these things?
    Jun 2010
    Dripping Springs, TX
    125
    My father's new pool (to him) has something attached to some of the pipes on the equipment pad that we can't decipher.
    They are the blue plastic things that are clamped on with zip ties. For lack of a better description, they look like ice cube
    trays on the inside where they touch the pipes.
    These are attached only on the return line - there is a 3rd one less visible in the picture above that is attached below the pool/spa return valve that is on the pool return line.
    Anyone have any idea what these are and what their purpose is?
    Thanks!
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    Jul 2011
    Central Califorina
    208
    Re: What the heck are these things?
    Google GMX pool water softner you will find what you are looking for. Looks like they sell for $400 to $600. IMHO snake oil that is not needed. I would leave then be untill they are in the way and then deep six them.
    All you need for good water quality is on this site, cheap, and backed by science.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    Jun 2010
    125
    Thanks - I've been browsing the GMX site. I suspected some sort of magnetic apparatus, as it didn't look like they pierced the pipes.
    I still can't find a description on their site of exactly how they work - a clear sign of snake-oil.
    It also claims they last 125 years, so I suppose they'll just attached.
    lol nice
    pool size 15X30 Filters:Cartridge Aboveground Plaster,Pentair Minimax NT Low NOx Series Heater
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    How they work? Simple... they tell you that you will see some benefit, one that you can sort of detect, if you check hard enough and well enough. You try it, and to see if it is doing anything, you monitor things more closely - after all, it's gotta have a money back guarantee, right? In the course of monitoring, you also do a better job of maintaining the water parameters, because you're testing daily and keeping a log, so your chemistry stays consistently better. Wow! This thing actually works! After a while, you accept status quo, go back to not checking and treating your water, and soon, the old problems are back. Oh well, it worked for a while.
    This was interesting, though... http://www.csicop.org/si/show/magnetic_ ... m_science/
    Nov 2010
    152
    But if you take them off your pool equipment, you can wear them as a bracelet and it will improve you health, too.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    They look like fancy dancy pipe markers to me.
    Return... =>> (that way)
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Look at these claims from the website(http://clearwatergmx.com/fivestarpool.shtml):
    After installation, run your spa continuously for the first five to seven days to remove the scale build-up from the heater and other surfaces. You must THEN drain and refill to the proper level and run for at least twenty-four more hours. This will purge the excess minerals from the spa water.
    In many circumstances, no chemicals are required to maintain crystal clear water with no scale build-up as long as the pump is run at least two hours per day.
    I wonder if chemgeek (or someone) might want to inquire with the industry about the last sentence bold claim of not needed any chemicals. Though maybe they just be refering to chemicals for scale buildup and not for sanitation?
    I can't find a scientific description on there site.
