Thread: I thought bleach was just sodium hypochlorite???
    Apr 2009
    Burlington, ON, Canada
    344
    What's all this other stuff in bleach?
    http://www.cloroxcsr.com/product-detail ... ularbleach
    Would I be better off using this instead, which looks like it's only in Canada, eh
    http://www.cloroxcsr.com/canada-product ... tingliquid
    I notice they both have a PH of around 12.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: I thought bleach was just sodium hypochlorite???
    As described in this post, Clorox Regular bleach is 6% sodium hypochlorite (chlorine), 4.7% sodium chloride salt, about 0.06% excess lye (sodium hydroxide), and a very small amount of sodium polyacrylate. All bleach and chlorinating liquid will have this ratio of sodium hypochlorite to sodium chloride due to the chemistry of the manufacturing process where chlorine gas is added to a solution of sodium hydroxide. The carbonate comes from carbon dioxide in the air.
    The only difference between the two bleaches you listed is the small amount of sodium polyacrylate in the Clorox Bleach. It is added primarily as a metal sequestrant of iron and manganese to prevent them from reacting with bleach and yellowing clothes. Since the normal dosage for Clorox bleach is 3/4 cup and a normal wash load is 40 gallons over multiple rinses (so say 20 gallons for the water used with bleach), then that is a 1:427 dilution or around 1400 ppm FC. In pools, the dilution is at least 100 times greater so the effect of the sodium polyacrylate is negligible though it will build up slowly over time possibly sequestering some metal.
