Results 1 to 12 of 12
Thread: See why I am getting depressed!
    Mar 2007
    Ontario
    211
    First winter with pool. Winter never seemed so long before!
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Guest
    I LOVE SNOW, but would rather have my pool open and it be 95 degrees.
    but whats the second step thing in your deep end?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,086
    I like the second picture better.
    Mar 2007
    Ontario
    211
    The step in the deepend is called a 6'Double Lounge. Its a formed fitting lounge.
    It has 4 jets in it and also blows air to created bubbles. You can isolate it from your
    returns to get full power when in use.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by JohnT
    Ditto
    Joyce
    You're done SLAMing when:
    Guest
    Quote Originally Posted by haybird
    i would love one of those.
    but i would also like the temp to creap its way past the frigid 60 and go for a more decent temp like 90 or 100.
    then i could open my pool, and not mind that the water is still 62 degrees ( used to be only 50 but we are having some warmer days, today was 78 8) 8)
    Hi Haybird,
    First time poster here. We are having a pool installed in a few months and looking for a dark liner. Love the blue in yours. Can you tell me manuf and pattern name?
    TIA.
    18x36 IG Vinyl Grecian Lazy L (20k gallons) ~ Whisperflo DS 2.0HP pump ~ QuadDE100 filter ~ Autopilot SWG DIG-60 ~ (7) 4x16 solar panels
    Haybird,
    How did you melt all that snow from one picture to the other?
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Musta used PhotoShop.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Ho Hummmm - I'm in the same boat. It's physically painful to look out there, so I try not to.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mar 2007
    Ontario
    211
    Nupoolsoon;
    Sorry I have not been on the site in a couple of days. The liner is made by Taylor Pool Products.
    Are pattern is called Arizona Brown. They have many dark blue liners. Are pool is new and one of the
    compliments we receive most is how blue the water looks. We are very happy with are choice. There was a picture around
    with the same pool with a light linner and then the replacement darker linner.
    Thanks for the information haybird. We have been considering what liner manufs call "tye-dye" and another one called "blue prism". I think your liner is (minus the tile area) is blue prism. Thanks again!
