Thread: Can pool be covered during shock time?
    Can I cover the pool during shock time to minimize chlorine lost?
    I think I have read somewhere that it should be ventilated, not sure tough.
    Intex round metal frame 15' x 42"
    Intex SWG / 2000 gph cartridge filter
    Taylor K-2006 test kit
    Outdoor pool with full sun all day long
    Typical temperture range in the 90's
    South Central NJ
    3,192
    Re: Can pool be covered during shock time?
    Uncovered is best.
    Scottt
    Owner of - PoolGuyNJ LLC
    Can you explain why?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    High chlorine levels will degrade a solar cover and make it brittle. Sunlight helps break down CC. I'm sure there are other reasons, but sunlight should only account for 2-4ppm loss of FC per day if your CYA level is 30ppm or higher.
    And you want the CC to disperse. Sun and wind is needed.
