Thread: How much can I drain my Pool?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I have a Plaster IG pool.
    My Cya is "around" 100.
    If I were to drain the pool, what is the safe amount you can drain a pool down? We have pretty high water tables usually in Florida I think.
    I'm interested in the max safe amount not only for now, but in case something needed to be done in the future for something else.
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    30,414
    Re: How much can I drain my Pool?
    Do it in stages. Drain say 30% and then refill. Drain 30% again and refill. etc.
    It uses a little more water (but not as much more as you would think) but makes it an absolutely safe operation.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Thanx!
    Not sure where you are but this might help ...
    http://waterdata.usgs.gov/fl/nwis/rt
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
