Thread: Can shocking damage the pool surface?
    I need to shock my pool since combined chlorine level is too high.
    I have been adviced to replace the water and not shock the pool since at high levels chlorine might attack the pool material and damage it.
    I own an Intex above the gound metal frame pool and my shock level is 13ppm.
    Is this a true risk?
    Avi.
    Intex round metal frame 15' x 42"
    Intex SWG / 2000 gph cartridge filter
    Taylor K-2006 test kit
    Outdoor pool with full sun all day long
    Typical temperture range in the 90's
    South Central NJ
    3,192
    Re: Can shocking damage the pool surface?
    No, not normally.
    Scott
    Owner of - PoolGuyNJ LLC
    30,421
    Absolutely not. That's why we teach testing and dosing carefully. 13ppm is fine..........200ppm will likely damage your pool.
    Did you consult the FC/CYA chart (in Pool School) to get that 13ppm?
    Thanks for the quick reply.
    I got the 13ppm from the pool calculator based on my CYA level.
    It said 13ppm for shock and 19ppm for mustard algae shock.
    Should I use the chart or the pool calculator is also good?
    Avi.
    30,421
    Either is fine. There is some variance but not enough to make any difference.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    What they said, with one caveat: If you use granular chlorine instead of bleach, don't just throw it in and let it sit on the bottom to dissolve. Unless you like polka dots.
