Thread: Size of the SWG I install this spring?
    Jan 2008
    Las Vegas, NV
    Greetings Jason, Waterbear and everyone...
    I am looking at installing a SWG on our inground pool and was wondering...since Temps in Las Vegas are extremely hot...
    Should I install a slightly Larger Unit (Autopilot ST-48 vs ST36) to help with the demand for chlorine generation in the summer?
    Also, it was not clear to me...does this unit allow for a temp triggered pump start up (freeze protection thermostat)?
    11070 gal Gunnite, Tahoe blue pebbletec, free form
    Pentair 420, PCC 2000 in floor cleaner, waterfall
    2 - 1 HP whisper flow pumps (floor cleaner & main)
    1 - 1 HP Pentair Waterfall pump
    Ft Lauderdale, Florida
    Hi Kevin,
    Thanks for considering AutoPilot.
    I would always recommend going with the largest size cell you can afford. Not just for the heat factor of Las Vegas, but also so that the cell will last longer before needing replacement.
    The Pool Pilot Digital, if used to control your circulation pump, has freeze protection so that when water temps fall below 40 degrees, it will activate the filter pump and check the water temp every 30 minutes to see to if it's falling below 40, in which case it will continue to run.
    During cold water temps, it will reduce the output of the system down to 1% when it is 55 degrees or colder (rather than shutting off). As it warms up, the % setting will increase automatically to increase chlorine production.
    Sean Assam -
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps
    AutoPilot Salt Chlorine Generators
