Thread: Pool Heater Care
    Pool Heater Care
    Hey all,
    I have a Raypack 140K BTU heater professionally installed. Check valve installed after the heater, with in an inline Chlorinator. PVC piping from the filter to the return pool return line. I have read and re-read the manual but, I am wondering what chemicals should I use and what chemicals I should not use. What should I check for as for as chemicals. It's brand new three months old no problems. I just want to make sure that I keep the corrison levels down. What would you recommend?
    Also, I live in Chicago, would you recommend winterzing it and leaving it outside or bringing it back inside for winter? Any and all suggestions will help.
    Thanks again all.
    12 X 24 Oval Pool, AG, Vinyl, 52" inch deep
    Sand Filter, 1 HP motor Waterway Model ?? OF flowrate
    Apr 2011
    Lynchburg VA
    393
    Re: Pool Heater Care
    I have a Hayward heater on my pool and as far as chemicals in the pool the only things I use are those chemicals associated with the BBB method. All of those get added to the pool directly in front of a return jet so that doesn't really affect my heater. Back in the day when I was getting pool stored, I added some chemicals (shock) directly to the skimmer but I bypassed my heater before doing this so the super chlorinated water did not pass through the heater. I think one of the main things you need to watch with heaters is your PH levels and keeping those in line. As far as winterizing, mine stays out year round but I am careful to get all of the water out of it when I close up shop for the winter. You are in a colder climate than I am and I think in your case I would cover it up for the winter.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Is there any test that should be done like for copper? Iron? Just don't want to damage a $1300 investment.
    Apr 2011
    Lynchburg VA
    393
    There is no test that I am aware of other than the normal testing of your pool water. The main thing with heaters seems to be not to run any corrosive water threw them and to drain water from them over the winter to prevent damage in the event of a freeze. As long as your PH is in line and you are not adding chlorine to your skimmer basket having it run threw the heater you should be fine.
    Pool School
    Pool Calculator
    Test Kits
