Thread: Filter leak
    Filter leak
    Hi there,
    I have a cartridge pool filter that has small leaks around the in and out fittings (bulkheads). Over the years the slab the filter sits on has sunk down a few inches so it no longer sits flat on the slab. One side of the filter rests on a rock wall also so it doesn't completely lie flat on the slab. I believe this is what has contributed to movement of the filter housing and possible leak. I attached some pics. Currently I have some rocks placed under the filter temporarily to try and have it on an even surface.
    Any ideas on how to:
    (1) fix the leak? I was going to try teflon tape on the threads to see if that did the trick
    (2) Provide a flat surface for the filter to sit on... I was contemplating using the hardening foam you can get in a can, spraying it up underneath the filter or possibly using a plastic bag as a mold for it so it doesn't stick to the bottom of the filter.
    Any advice appreciated - thanks!
    Blessed is the man who can laugh at himself for he will never cease to be amused.
    To teach is to learn twice.
    My Pool. 20 x 40 120,000 litres (about 30k gal) sand filter, a pump of some type...lol & a bunch of neighbourhood kids.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Filter leak
    Welcome to TFP!!
    Leveling the filter was a GREAT idea!!
    Can you post a close-up of the bulkheads? It may be as simple as an o- ring stretched too much from the filter being out of level -- or... it could be cracks in the filter body itself The filter looks 'older' do you know how old it is?
    I'm pretty sure I can get you through this season, even if the filter is cracked
    Luv& Luk
    -Ted
    Re: Filter leak
    Thanks, Here's a close up of the bulkhead, red arrow points to the leak. Not sure how old the filter is, I've been here a little over a year and the house is about 9 years old, so I assume the filter is pretty close to that.
    22,551
    Re: Filter leak
    Can you take a side shot of that so we can see how much stress the filter being out of level is putting on it if any.
    Have you tried just tightening that nut?
