Thread: New Pool - Salt keeps running low
    Jul 2011
    Richmond VA
    52
    Hello,
    We have a new pool about 16K gallons. Initially we started with 10 @40 LBs. Since we had so much water issues with silt, alot of the water has been "wasted" out. That was last Tuesday the 16th. The SWG complained that it had low salt so I added 6 bags since. Yesterday the SWG said there was about 2800 ppm. This morning it says there is 2300 ppm. Is that normal?
    Last night I got in my TF100 test kit and measured the salt and it was at 2440. My pump runs 24 hours. When no one is using I have it running at 1000 rpm. My FC is 4.5 and CC 0.5. (Last night) I have changed the Chlorine creation percentage down to 20%. Perhaps that is still too high?
    16.6 x 32.6 Vinyl Liner Grecian, Aqua Rite Plus SWG, Hayward HeatPro 110K BTU, Pentair VRS, LED Laminar and Interfab Waterfall.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New Pool - Salt keeps running low
    What is your CYA level? Refer to the CYA chart for the recommended FC level for your CYA.
    I don't like to rely on the SWG units for salt measurement - are you using strips or the Taylor salt test?
    Jul 2011
    Richmond VA
    52
    My CYA is around 40 -50. I was using the Accucheck Salt Strip. It said it was 2440 last night. With the system saying 2300 this morning, I suppose it is within the margin of error.
    22,542
    Do you have an autofill? If so it could be masking a leak and that would explain the salt loss.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    You could also have a lot of rambunctious kids doing cannonballs or creating tidal waves or any number of other ways to create massive splashout.
    Jul 2011
    Richmond VA
    52
    No do not have autofill... I have been doing the bucket test and it appears no leaks.... I am a little paranoid given we have had the pool for a whole week now. What it turned out to be was that the salt had not fully circulated.... thought it would have done so after 24 hours. When I came home from work on Saturday it was back up to 2700. I put one more bag in and now after 2 days... it is at 3300. Got the water tested at another facility and the SI was at .07, guy said that was really good. My CYA is still a bit low, but then I noticed I still had some in the skimmer that had still not dissolved after 4 days. I'll wait another week to check it again.
