Results 1 to 10 of 10
Thread: How to dispose of Muriatic Acid after soak?
    Jul 2011
    Greenwood, Indiana
    42
    We are going to soak our SWG cell in muriatic acid to clean it (and hope it fixes it). But once it's done soaking, how do we dispose of the acid? Also, Hubby wants to soad it over night, will that be too long?
    18,000 gallon in ground SWG sand filter electric cover
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,857
    Re: How to dispose of Muriatic Acid after soak?
    You're only talking about a small amount, right? Why not just pour it in the pool?
    Jul 2011
    Greenwood, Indiana
    42
    Well we were planning to submerge it in acid so depending on the size of the container we find to soak the cell in, it would probably be more than we usually put in to lower the pH and if it's cleaning stuff off of the cell, not sure I want dirty acid poured in my pool, do I?
    Richard320's Avatar
    Jan 2010
    18,857
    Well then, you could use it to scrub stained concrete, the driveway, perhaps? Or just neutralize it with baking soda (watch out for violent foaming) and pour it on some weeds or down the drain.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    violent foaming. lol sounds like a fun chemistry experiment...haha
    http://www.PerfectlyClearPoolService.com
    Baking soda is the best approach: add baking soda fairly slowly until it stops foaming up, then pour down the drain with the water running.
    Pouring it back into the pool adds calcium back to the pool, which could be a annoying in some situations.
    Jul 2009
    London and France
    574
    A lot of the acid's initial power will be neutralised by cleaning the calcium and other deposits off the plates in the cell. Put it down the toilet and let is descale that too.
    I always pour mine over the fence in the neighbors flower bed JK!
    31,000G IG vinyl 20X40 True L. Hayward 1.5 superpump, Autopilot Pool Pilot Digital SWG, Hayward Model S244T 300lb sand filter, TF100 kit
    Oct 2010
    Pensacola, FL
    67
    You do know that you only put the acid INSIDE the cell, don't soak the whole thing; the outside should not get acid on it. Then after cleaning u should be able to dump it in the pool.
    Bill Moyer
    CWO4 USN (Ret)
    Pensacola, FL
    10k gallon 12x24 in ground pool built 2008, vinyl, Pentair Intellichlor IC40, Pentair Intelliflo v/s pump, Hayward sand filter. Using the BBB method.
    kenandshari's Avatar
    Aug 2010
    Savannah, GA
    134
    We're first year pool owners so we are not as experienced as many out there on TFP. The local pool store where we buy our acid instructed us to mix it 1 part acid to 4 parts water, then stuff a tennis ball into one end of the cell to seal that end, (or buy some special cleaning kit that caps it off) and let the solutin soak inside of the cell until the bubbles stop but not longer than 15 min. We set the whole thing in a bucket while doing this to prevent acid leaking out into the lawn.
    Ken & Shari
    Savannah, GA
    16' x 40' freeform fiberglass inground (Pacific model, mfg by Tallman Pools), 23k gal, 2" plumbing throughout, Intellichlor IC-40, Easy Touch controller, Intelliflow VS 3050 pump, Pentair Clean & Clear Plus Quad Cartridge filter. 4 Jandy deck jets (3/4" plumbing), Fiberstars color changing lighting, SR Smith salt friendly diving system, Interfab Wild Ride slide, Aquasol Solar Heat (5 panels 4'x12' DIY install automated with ET) RIP Nitro Wall Climber Mar 2011-Aug 2012, Nitro is survived by a Polaris 360.
