Results 1 to 7 of 7
Thread: FC
    Jul 2011
    Terre Haute indiana
    60
    FC
    after shocking was complete a couple of weeks ago the fc would fall from 7 to 4.5-4.0 during the day last couple of days its dropped to 3 and the cc is up to .5 its usally been 0 any thing to be concerned about. try to test about the same time every evening
    19500 gal, IG, haywood s-200 sand filter & pump, 3/4 horse single speed motor, vinyl liner, tf 100 test kit, installed early 80's, Terre haute,In
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: FC
    Kinda sounds like maybe shocking isn't really complete. What's your overnight loss? In fact, what are all of your test numbers?
    30,432
    Re: FC
    Has it been a little hotter lately? A few more swimmers? Either of those could account for the increase.
    Re: FC
    Dogs in the pool? Leaves blown in? CYA too low?
    The way to know if shocking is needed is to do OCLT. If you lose chlorine in the dark with no one in the pool and skimmers, etc, clear of leaves, then you have organics in the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: FC
    I'll just echo what duraleigh said. One really sweaty body can use up a lot of FC.
    My CC goes up and down for no reason. Sometimes I'll get .5 for days on end, and then it will read nothing for a few days. Yesterday I had none. No one used the pool. This morning I had .5. If you're worried, use a heavy hand on the bleach dosage. And check the skimmer. Even if they're not in the pool, leaves and pollen are still in the system.
    Jul 2011
    Terre Haute indiana
    60
    Re: FC
    thanks all, has gotten hot again the last few days i'll keep a checking
    May 2011
    Clearwater, FL.
    446
    Re: FC
    Quote Originally Posted by Richard320
    A 0 to .5 of up and down is very normal, mine acts just like Richard's.
    I did get up to 1. CC after a heavy late nite swim (or should I say a big, pass the bottle !) with lots of the extended family. (I also heard the dog was in the pool too!)
    I just went up to about 9 ppm FC in the morning after seeing the 3.5 FC & 1 CC and by the evening was 6 PPM FC and 0 CC
    My CYA is 40.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
