Thread: Just getting my feet wet!
    Just completed my inground pool! I was able to do the entire installation myself with the help of friends and family willing to sweat it out!
    28000 gallon True L 40X32X16
    Hayward 1-1/2 pump
    Hayward SWG
    Hayward 244 Sand Filter
    3 Skimmers
    2 bottom drains
    4 returns
    Just confirmed my own water test from Taylor k-6000 with the Leslie pools here in town to see if I was close:
    FC 2.5
    PH 7.6
    TA 80
    CYA 10 (i just added 10 lbs tonight after backwashing)
    CH 125( not to concerned as I have a vinyl liner)
    TDS 2000
    Salt 3400
    After reading the post "water balance for SWG" it looks like i need to get CYA to 70? I have never seen recommends this high and was wondering what effects this will have on PH or other parts of the pool?
    I was also confused on how you would shock a SWG pool if you follow the BBB method? I assume some huge amounts of bleach? I hope this is not needed...but I dont want to be scrambling either.
    Thanks for any advice!
    Robert
    Robert
    28000 gallon
    1-1/2 hp pump
    244 hayward sand filter
    Hayward SWG
    BBB method rules!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Just getting my feet wet!
    Hi Robert, welcome to TFP! If you ever find you need to shock the pool then yes you would want to use bleach instead of your SWG. That will save wear and tear on the SWG. We would love to see a picture of your new pool! Enjoy!
    Love TFP? Become a
    TFP Supporter!
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Sounds good ... looks like you dosed your CYA to 53ppm (10ppm to start, and an additional 43ppm) as I see it using the http://www.poolcalculator.com for 28,000 gallon pool.
    Here's my 2 cents (maybe only worth 1) ...
    1) Be sure you have "troublefreepool.com" chosen under the dropdown in the "Suggested Goal Levels" section.
    2) Be sure to have 28,00 gallons listed under "Size"
    3) Be sure to put your CYA as 53ppm in the "Now" column for CYA
    4) Now you can see your "range" (in relation to CYA) for your FC level
    5) Double and Triple check ALL numbers and fields !!!
    6) Dose your pool either to your maximum "target" or 1ppm or so above it about an hour before sunset for the next day usage. (forgot you have SWG, so "dose" your pool accordingly with the turn of a dial)
    If you know your usage for the next day will be high (ex- the three H's (hazy, hot, humid), a lot of people swimming, or other factors) you may want to "dose" your pool 2-3ppm above your "maximum" target level to account for the chlorine demand (i.e. - turn up your SWG or adjunct it with liquid chlorine). Whatever you do, try not to let your pool EVER go below the "minimum" target level (in relation to CYA)as this will only invite uninvited guests to your pool and party
    As for pH, TA, CH, and the like ... I am sure a more knowledgeable person will chime in here.
    Good luck with that pool .... one day you will catch sparklypoolitis !!!!
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    Quote Originally Posted by zea3
    Thanks, here is a pic that shows where I am...lots of landscape to do!
    Robert
    28000 gallon
    1-1/2 hp pump
    Hayward SWG
    BBB method rules!
