Results 1 to 11 of 11
Thread: closing
    closing
    What numbers should I aim for when closing the pool?
    17K gal, AG, Hayward Sandfilter, new to the BBB method.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,388
    Re: closing
    Here are the instructions for closing an above ground pool. Keep in mind that if you close your pool before the water temperature stays below 60 degrees you may still have an algae bloom when you open the pool.
    Love TFP? Become a
    TFP Supporter!
    Re: closing
    I read the directions just not sure about the ph, but I suppose if it is within the range it is ok. Good to know about the temp. I had not thought about that. It is chilly, around 75. Too cold for me but the kids don't mind.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: closing
    Quote Originally Posted by randadawn77
    Closing.......guess that is going to be a more frequently used word around here.
    Essential Links:
    Re: closing
    Just finished brushing and cleaning the pool. The water temp is 78, but it feels 60 to me. brrrrr
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: closing
    Yeah, I like it at 85 a whole lot better. Where is Frog on this one? She swims in ice water all the time.
    Essential Links:
    Jul 2009
    Houston, Texas
    9,388
    Re: closing
    My area is under stage 2 water restrictions, which include no topping off the pool. I am using my vacuum to draw water from the bottom of the pool. I set it up last week before the water level got too low. If I were to take it off now I would not be able to run the pump. Really need some rain around here.
    Love TFP? Become a
    TFP Supporter!
    Aug 2010
    Boston, MA
    176
    Re: closing
    Heh - in MA, we're lucky to get up to 75. 85 is just crazy talk.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: closing
    Closing???
    Already? wow...
    Summer just started :~}
    If I had any sense I would have left it closed till last week. But then y'all would have missed out on all my self imposed pool drama.
    It CAN be warm through September around here but that's unusual. I'll close a few weeks after school starts if the sun sticks around. They will come home after school and swim for an hour if the sun is out, regardless of temp.
    Are y'all closing because the pool isn't getting used or are you just sick of messing with it? If I had a heated pool I'm pretty sure I'd leave it open year round. There's a pool at Timberline Lodge on Mt. Hood. I swam there as a kid in in a snowstorm, it was totally awesome.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: closing
    Northern Ontario, my AGP was 68 this morning, our nights are just getting too cold and are out weighing the day time heat into the pool.
    Ordering a winter cover at the end of the week and I'm going to hold out hope for a nice Sept rush of heat, otherwise its getting closed down soon.
    I'll need to get a solar heater next year.......honestly, I can't even remember what occupied our family time before getting the pool up this summer, all our free time was spent by the pool......best summer ever!!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: closing
    Quote Originally Posted by Brushpup
    Frog does not swim, but her tadpoles do...
