Thread: Inline puck feeder question.
    May 2009
    Seminole, FL
    71
    I have a Pentair inline feeder that works with 3" pucks. Question I have is the amount of chlorine put out proportionality higher in comparison to the amount of pucks you put in? For example, if I use 8 pucks and find a setting that maintains about 5ppm of Chlorine a day, if I use 4 pucks and keep the setting the same will it only output about half the amount of chlorine?
    I only use it when I am on vacation so I am trying to determine how many pucks to put in while I am out.
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    South Central NJ
    3,192
    Re: Inline puck feeder question.
    If the unit is set in it's default configuration with the feed tube in the lower position, it doesn't matter. The control valve dictates how much water goes in and the # of tabs is moot. Only one or two tabs get watered.
    With the feed tube in the upper position, water washes over all the tabs and thus, larger pools can be accommodated as more of the tabs are exposed.
    Scott
    Owner of - PoolGuyNJ LLC
    May 2009
    Seminole, FL
    71
    What is odd is that if I open it, it fills to the top with water. it's in the default configuration the hose at the bottom. Unless it only fills up all the way because I have the top open?
    South Central NJ
    3,192
    The pressure from the captured return water builds enough pressure to overcome the internal check valve and forces the freshly chlorinated water out of the chamber. When the pump shuts off, the pressure in the chamber pushes the water out, leaving the tabs dry.
    Scott
    Diver's Avatar
    May 2011
    South of Boston
    450
    Quote Originally Posted by Crimson
    i have the similar problem - the chlorinator fills almost all the way up and it also doesn't drain when the pump is off or the regulator is set to 0. i suspect the check valve is faulty. i thought about replacing the valve which cost a few bucks, but since i only use it when i'm on vacation or when i need to bump up my CYA and take it off the pipe the rest of the time, i decided to leave it as is for now.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
