Thread: Solar cover pulley
    Jul 2011
    Brookfield, WI
    131
    Solar cover pulley
    Greetings,
    My pool is in-ground and in a lazy-L shape. We have a solar cover, but it is rather hard to close the pool and the reel we have is old and not smooth. The cover that was in the house when we bought had a two board and rope attached to the end so we pull it all the way to the other end to cover the pool. Now we changed the cover but not the reel. I need a way more efficient than the old boards and rope to close the pool. Ideas? Suggestions?
    Thanks. Be well
    Miriam
    20 x 44 in-ground vinyl
    Hayward Pro-Series High-rate sand filter (S310T)
    Nature2 Zodiac chlorinator
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: Solar cover pulley
    Instead of a board, why not just use rope and get yourself some tarp clips to attach to the cover?
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Jul 2011
    Brookfield, WI
    131
    Sounds like an idea. I will check that out and hopefully I will be able to implement it.
    Thanks. Be well
    Miriam
