Thread: French Drain Help.
    French Drain Help.
    hello,i have a new above ground pool. the pool has a deck with an under deck slope about four feet of slope. i built a french drain at the bottom about a foot and a half in front of the pool where about a foot of water collects every time it rains. i did the black fabric and the crushed stone and the proper slope with the drain pipes, now what do i do with the end where i need the water to flow away from the pool. can i just dig a big hole and fill it with crushed stone and let it flow into the yard under ground? thanks
    30,413
    Re: French Drain Help.
    Sometimes. It depends on how well the soil "perks" (absorbs moisture). Is there a way you can continue the drainpipe downhill and let it run out into a lower area? That's better than digging a hole although the hole may work if your soil is good.
    Feb 2011
    Sicklerville, NJ
    80
    Either put a drainage tank underground or terminate in a pop-up drain above ground
    http://www.lowes.com/ProductDisplay?productId=3130115
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    ConcreteJack's Avatar
    May 2011
    Williamsburg, VA
    42
    French Drain Help.
    Keep digging so that you can get the end of the pipe well away and below grade from the pool; it's completely counter productive to take surface water and put it below your pool by digging a sump pit.
    I am here: http://maps.google.com/maps?ll=37.661229,-77.460077
