Results 1 to 20 of 20
Thread: 13 yr old finds more efficient arrangement for solar panels
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Guy sees Fibonacci seq in trees, sets up experiments, develops more efficient arrangement for solar panels. He's 13 years old.
    http://www.amnh.org/nationalcenter/youn ... aidan.html
    Re: 13 yr old finds more efficient arrangement for solar pan
    Wow. I love his idea and the possibility of seeing solar-trees in the area would be a sight. Energy cost could be a lot lower if we all tried to grasp these ideals.
    Newbie in Hampton, Virginia
    TF-100 test kit
    18' round x52" /Sharkline Heritage /8000 gal /vinyl AGP
    Intex 2650 GPH, 1 HP, sand filter and SWG combo
    Solar cover
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Yeah, this kid is fairly impressive. I'm reasonably sure that when I was 13, I could barely see a pattern in the sun coming up each day.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by Ohm_Boy
    LOL! "Wow, it came up east again today....does it always do that??" I'm with you though...very, very impressive for a 13 year old. Heck, that would be impressive for collegiate level, I would think.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    I wonder if he got the idea from here:
    October 15, 2008 11:59 AM PDT
    Open Energy makes solar panels and this nature-inspired solar collector. Although it also has an aesthetic appeal, the product was designed to maximize light intake in a small space, like a tree does with its leaves.
    http://news.cnet.com/2300-13840_3-6247072-8.html
    I also think that his method is fundamentally flawed. He measured voltage when he should have been measuring power.
    My idea was to track how much sunlight each model collected under the same conditions by watching how much voltage each model made.
    Support the site
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by JamesW
    [quote:2tkf6ef6]My idea was to track how much sunlight each model collected under the same conditions by watching how much voltage each model made.
    [/quote:2tkf6ef6]
    Ehhh, maybe, maybe not. I'm going to go with the kid on this one.
    BTW, you can't have power without voltage, if I remember Ohm's Law correctly.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    You can have power with a waterwheel. Or a gun. Can't have ELECTRICAL power without voltage.
    Ohm's Law - words to live by.
    Quote Originally Posted by MikeInTN
    Yes, however, voltage is not the same thing as power, and power is what matters. Measuring just voltage is not a valid test of a generator.
    Support the site
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Well, technically, it is directly related to power, if there is a consistent load on the panel.
    P=E^2/R, so with a given resistance, the power is proportional to the square of the voltage. The meter itself presents a load resistance, and it is generally consistent over the measurement range.
    Mar 2007
    San Rafael, CA USA
    12,082
    If the internal resistance of the generator is high, then a high voltage does not imply high power since any significant current draw can significantly drop the voltage. This is what happens (chemically) when batteries get weaker. A seemingly dead battery need not be at near-zero voltage. Even though it can appear to be at 80% of its full voltage, putting any reasonable load on the battery can cause the voltage to plummet and the power output to be very low.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    This is true, and the internal resistance of these generators (PV Cells) is going to be considerably less than that of the meter, if there is no additional load. All other things being equal, more light yielding more voltage will equate to more power.
    When measuring open circuit voltage, there is no current flowing, and therefore, no power. Voltage is only weakly dependent on light intensity whereas current is more closely related to light intensity.
    Support the site
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    There is always current flowing through the meter. It ain't much, but it is there.
    http://www.mtmscientific.com/solarpanel.html
    I think that my original point is valid. Measuring only voltage is not the proper way to measure the output potential of different solar panel configurations.
    Support the site
    Measuring voltage is just fine if you have some plausible fixed resistive load. The article is consistent with the possibility that there was such a load, though it never mentions if there was or not.
    Apr 2011
    Somewhere on the Emerald Coast
    156
    You guys are giving me a headache !!! Active and Passive Networks was the absolute worst class I took in college!!!! ACK !! I'll take Strength of Materials or Statics and Dynamics any day !!!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    Jul 2010
    England, UK
    156
    In the photo with the article, the boy's fixed panel has 10 collectors and the tree-arrangement seems to have 16...
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Quote Originally Posted by Flotsam
    I'll take Rocks for Jocks for $200, Alex......
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Quote Originally Posted by loop_pea
    Yes, it does seem as though the tree has more solar cells than the flat panel.
    Perhaps the awards committee placed more emphasis on concept than on execution or technical merit.
    Support the site
  20. Back To Top    #20
    Apr 2011
    156
    Quote Originally Posted by ivyleager
    ROFLMAO !!!!!
