Results 1 to 8 of 8
Thread: Brand New Spa newbie! Need help.
    Aug 2011
    Blanchard, Oklahoma
    26
    I have had my spa for about a week and a half and it has a continous ozone pump. They told me to check ph once a week and add baking soda to raise it or ph decreaser (that they provided) to lower it. Throw one bromine tablet in the skimmer basket per month, and use something called spa magic that helps with foam and breaks down body oils etc. I have had problems with cloudy water, way to much foam. I have tried spa shock and defoamer with success on then foam, but can't seem to get the crystal clear water. They gave me the strips to test for ph, but I had trouble reading them so I went and bought a chlorine/ ph tester and have used that. My ph did get a little low on time and I added some baking soda and brought it up fairly quick. Once again I know absolutely nothing, but they tell me the ozone takes care of most and the 1 bromine tablet gives that a back up. What else do I need to be doing? What am I doing wrong? Any help would be great.
    30ft x 54in AGP 24,900 gallons
    400 lbs High Rate Sand filter
    2HP, 2 speed pump
    Pool Install April 2012
    Aug 2011
    Blanchard, Oklahoma
    26
    Re: Brand New Spa newbie! Need help.
    Really no one has any suggestions?
    2HP, 2 speed pump
    22,398
    I guess our spa guys are out soaking.
    Maybe one will stop by soon and give you some advice.
    Mar 2007
    San Rafael, CA USA
    12,082
    As you have found out, ozone alone does NOT keep a spa clean. Even with bromine, most users find they need to use chlorine about once a week or so to keep the water clear. Now that said, a new spa always has a lot of junk in it and the first fill will always be bad. This is why it is recommended on the first fill to use Spa System Flush to remove biofilms and clean out grease that may be left in the spa from manufacturing and wet testing. You then dump the water and you refill and should be good to go. I'll bet that if you do that, you'll be in much better shape. For a completely thorough cleaning, you can also superchlorinate (that procedure is described here, but I think if you use Spa System Flush and then drain/refill you'll be OK).
    Even with ozone, you'll likely need more bromine than you have been using. You can read more about Using Bromine in a Spa or if you decide to switch to chlorine with the Dichlor-then-bleach method then you can read Using Chlorine in a Spa instead.
    Jul 2011
    Central Califorina
    208
    Please, disregard all advice you got from the spa store. It's obvious they know little of proper water chemistry/sanitation.
    If you will follow the advice already posted on this site you will have crystal clear water that feels and smells great.
    I use Chem Geeks dichlor/bleach method and sanitize my tub for less than $20 a year.
    We will be happy to help you after you read up a bit to decide how you want to sanitize your tub and buy one of our recommended test kits. Without a good test kit we will not be able to help you.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    Aug 2011
    Blanchard, Oklahoma
    26
    Thanks for the replies. I am installing a pool next spring also. Is there a way to get a good tester that will work for both the pool and spa? Even if one is chlorine and one is bromine? If so what test kit should I get?
    2HP, 2 speed pump
    Mar 2007
    San Rafael, CA USA
    12,082
    You can use a good chlorine test kit for your bromine spa as well. So get either the TFTestkits TF-100 or the Taylor K-2006. When you test your spa, you will just multiply your chlorine reading by 2.25 (roughly 2) to get a bromine reading and you will skip the CC test. That's really the only difference.
    May 2011
    The Netherlands, Europe
    49
    A little late (sorry) but indeed: the pipes will have been dirty. So, clean the tub, change the water and start over. Also, you may want to check your cartridge filter. If I let them get too dirty they don't filter the water properly. Just hose them down and let dry, while you place another filter in the tub.
    Hope you will be enjoying the tub!
    Sunspa Monaco in the garden since March 2011.
