Results 1 to 8 of 8
Thread: Adding salt as a softener
    htownjeeper's Avatar
    Aug 2011
    Nassau Bay, TX
    199
    I know I've seen it somewhere on this site, but to be honest, I've done so much reading here I can't remember where I saw it. What is the panel's opinion of adding salt as a water softener? If someone knows off the top of their head what section that was in, I would appreciate you pointing me in that direction!
    Does anyone here do it? Opinions?
    22,000 inground Fiberglass
    DE Filter Pentair FNSP 48
    Century Centurion 1.0 HP 1.25 S.F. 3450 RPM
    Jul 2011
    Central Califorina
    208
    Re: Adding salt as a softener
    I dont know where is is posted but before I went with a SWCG I kept the water in my pool and hot tub at 2000 ppm salt. I thought it made a difference in the water. You should start with a salt test kit as chlorine could already have you above a salt level of 2000 ppm. The only way to remove salt is drain/refill.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Adding salt adds a subjective water feel improvement. It doesn't soften it the way a water softener does (exchanging calcium and minerals for sodium ions). If you need to soften pool water you need to replace the water with softer water, such as rain water or tap water if its softer. Alternatively, you can have it treated with RO or truck water in.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Aug 2011
    Nassau Bay, TX
    199
    Found it. It was just a brief mention under the "BBB" section. JasonLion mentions it briefly as a water softener even if you aren't using a SWG. Ok, I was just pondering it really. I can't complain too much about my water because it's perfect to me. I was just wondering if I was missing out on something.
    Thanks.
    Jul 2011
    Central Califorina
    208
    A teardrop has a salt content of 9000ppm, Saline IV fluid has a salt content of 9000ppm. One difference I notice with my salt content is if you spend alot of time in the pool you dont come out with pruned skin. The has to do with osmosis. Water with a higher salt content will waterlog the skin less as it is closer to the salt content of the skin.
    Taylor K-2006
    Aug 2011
    Nassau Bay, TX
    199
    Quote Originally Posted by BBBliever
    What is your level?
    Jul 2011
    Central Califorina
    208
    With my Intex SWCG I keep my salt level around 3500ppm. I will admit the feel is subjective, but at 2000pmm I noticed a difference. Maybe it was a metal thing. Regardless I like the water better.
    Taylor K-2006
    I keep mine at 2000 and love it. I feel a difference between that and not having added the salt.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
