Results 1 to 9 of 9
Thread: Chemicals
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Chemicals
    Can someone tell me where to find the chemicals for the pool. I know borax, bleach at walmart etc...where is the best places to get CYA or MA and the other stuff. Pool is opening next week and I want to be prepared.
    Thanks a lot !!
    15x30 free form (10,500 gal) SWG
    Gunite, Game depth 3.5-5-4 ft, 1 hp Sta-Rite Super Max 2 speed pump, 53' Sta-Rite system 3 DE filter
    Pentair Intellibrite LED
    Pentair 125k BTU ultra temp heat pump,
    Screen Enclosure
    TF-100 Test Kit
    Optica's Avatar
    Jul 2011
    Southern California
    70
    Re: Chemicals
    most people get CYA at Walmart..The HTH brand. MA can be found at Lowes or Home Depot and there is always the pool store but they are usually not the cheapest.
    ___________________________________________________
    12,000 Gal IGP, Gunite/Plaster, Pentair DE & Pump, Heliocol Solar, K-2006, BBB'd & Borated.
    Jun 2011
    Cape Girardeau, Mo
    125
    Re: Chemicals
    I always find that Ace Hardware and Tractor supply company are the cheapest around here on Muriatic acid make sure it is 31.45% the Lowe's here only stocks 15% . The CYA at walmart is called HTH stabilizer and conditioner it seems to dissolve really fast and so does GLB brand that some pool stores carry.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Re: Chemicals
    I have learned where some of these were found, was not sure the brand names and locations of some of the other daily stuff used.
    Screen Enclosure
    TF-100 Test Kit
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Re: Chemicals
    Where does one find washing soda? Also I read in a different posts that 20 mule borax also has a laundry detergent and not to get them confused....are there two types on the laundry aisle?
    Screen Enclosure
    TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Chemicals
    Since you have a brand new plaster pool, you will mostly need lotsa MA to keep the pH under control. Brushing your pool and testing pH and adding MA will be your new job for a while BTDT
    It is recommended to use an auto chlorinator or floater with trichlor to start off. It keeps some chlorine in the pool and also helps keep the pH under control. Once the CYA reaches a desired level switch to liquid chlorine or; (after at least 30 days or so) you could add salt and start the SWG.
    Have you seen the plaster start-up article in Pool School?
    If you want to keep something to raise pH, get the borax and get baking soda to raise TA. You can treat each issue separately if needed, so skip the washing soda (which addresses both issues). This keeps things very simple.
    Have you tested your fill water? Do you know the TA, pH & CH?
    We could better advise chems if we know the fill water test results.
    Now take that brand new TF100 and test some water for us!
    btw, your pool is gorgeous!
    You're done SLAMing when:
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Re: Chemicals
    Butterfly, thanks a lot for great info. They are plastering tomorrow and I will fill and test fill water tomorrow night and post results. It is weird that I am a bit nervous as I never had a pool before but I have read and reread a dozen times pool school and posts, thanks again !
    Screen Enclosure
    TF-100 Test Kit
    Jul 2011
    Las Vegas, NV
    37
    Re: Chemicals
    Quote Originally Posted by fsteve65
    I've found MA at Lowe's in two places within the store. In the outdoor or pool section, they carry 15.7% MA, and its sold 2 gallons at a time under "Kem-Tek Pool Muriatic Acid." In the paint section, or wherever you'll find concrete cleaner, they sell 1 gallon bottles of 31.45%. They also sell "Green Safer MA" but I couldn't tell how strong that was, or even if it was the same stuff. MSDS indicated the Klean-strip Safer stuff has an HCl concentration under 25%, but nothing more specific.
    33k in-ground plaster pool and spa / Goldline T-15 SWG w/ Aqualogic controller / RS2000 Hayward pump / Pentair Clean & Clear Plus 420 sq. ft. cartridge filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Chemicals
    Quote Originally Posted by mvk111
    You can go ahead and test your fill water from the tap tonight/tomorrow if you want.
    It will give you an idea of what you can expect. Only test for TA, CH & pH.
    Don't be nervous, your TFP buds have your back! Just be excited!
