Thread: Pentair Whisperflow Motor Loose?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I have a 1 HP Pentair Whisperflow pump. It is working fine, except for one thing.
    I was cleaning out the basket and noticed when I powered it back up, I saw the motor move.
    It was hot and I couldn't investigate further at the time.
    So last night after it had cooled down, I grabbed the end of the motor and it moved quite a bit, I could rock it up/down and side/side.
    When I say quite a bit, I mean it moved easily, and quite a bit because it seemed to me it should be tight.
    I took a socket out there and tried the bolts on the motor flange and they were all tight. I loosened one and re-tightened it to make sure they were not just "bound".
    I called Pentair today and they really were not much help.
    Anybody seen this?
    I have no water leaks, the pump works well and is not noisey.
    The only issue I have is air in the basket that I am trying to track down. Don't now if it could entrain air there and not leak water, doesn't seem like it though.
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    22,549
    Re: Pentair Whisperflow Motor Loose?
    Take a real close look at it and see exactly it's loose at. It may be the seal plate on the pump. If it is you'll need to tighten the seal plate bolts.
    Here's a topic that will show you ho it's assembled.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Thanx! I was just watching a Youtube video about this, but it wasn't near as good as the write up.
    I looked over the pump again and found my problem. The thread boss/mounts for the motor are broken on the seal plate. I don't know why it isn't jumping all over the place! I don't think they are all broke, but it looks like more than one is.
