Thread: Should I pay the builder for chemicals on a new pool install
    Jun 2011
    Atlanta Georgia
    2
    I am considering a quote on a pool and the pool builder is charging $325 for chemicals after it is filled. The pool will be filled then not used until next year since it won't be complete until October. Is $325 reasonable and should I just expect that for a 18x36 rectangle with an 8' deep end? Should the pool be brought to full swim chemicals before wintering over? We plan on using the BBB method and we will not have salt.
    1: 10,000 gals in the ground plaster, Hayward pump SP2715X20 2hp
    2: Aqua Rite Electronic Chlorine Generator / T-Cell-15, Hayward Pro-Grid DE Filter Model DE3620
    3: AquaCal Heat Pump, Astrlite SP0580S Under Water Light
    4: Port PolarisCaretaker, TFTestKit-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Should I pay the builder for chemicals on a new pool ins
    What kind of pool is it? If it is plaster/pebbletec etc., I would think the startup chems needed should be included in price. If it is vinyl, then I would forgo the pb chems and get your own. It won't cost you $325.
    Jun 2011
    Atlanta Georgia
    2
    It will be a vinyl pool.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    You should be able to plug your numbers into the pool calculator and assess the costs to buy everything used in BBB.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    You'll need salt, bleach, baking soda, maybe some borax (BBB) and perhaps muriatic acid.
    Not $325 worth at all.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    30,432
    If you go with that builder, just have him remove that from the cost. You will be a far better judge of what chemistry you need (very little) if do your homework.
