Thread: Pentair valve - 261050
    Would like to know the what the different settings on the multi-port valve are.
    Filter - normal operation
    Waste - ?
    closed -?
    backwashed - clean filter
    recirculate -?
    Rinse - ?
    20x40 gunite inground roman shape 7 ft deep end, 1hp hayward main pump, 2hp in-floor cleaner pump for Paramount PV-3,all plumbing 2" sch 40, Nitro wall climber robot, Fiberstars WPC-2, ColorLogic LED lights, Hayward 425 sq. ft. cartridge filter, UltraPure UPP25 UV ozone.
    Re: Pentair valve - 261050
    Waste - sucking the water directly to drain
    For vacuuming stuff you don't want in your filter
    Closed - just what it says. It closes everything.
    Recirculate - bypasses the filter
    Rinse - used after backwash to flush the lines clean before going back to filter.
    Rinse till the sight glass is clean then back to filter.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    thanks!
