Results 1 to 10 of 10
Thread: Cracking / broken cement
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    The extended 100+ degree weather here is taking toll on the clay soil in our area, I had to start a soaker hose around the house, and the cracks in the concrete around the pool ate getting bigger in some places. One is pretty bad, we just had a 12 x 20+ concrete "lay in the sun" pad portion near the shallow end replaced.
    From what I understand, this is a lot of work since the coping is actually in the concrete?
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Re: Cracking / broken cement
    It might not be so bad. You could use a concrete saw to cut out the cracks and fill them in with new concrete.
    Support the site
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    But Wait! There's MORE! haha
    The crack on the right (above) didn't open up until this year.. i mean, it was there but for 2 years it was the same.
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    corners and skimmer...
    K-2006 Test kit
    I know that it looks bad. However, I think that if you just use a diamond saw blade to cut the cracks out and then fill them in with a sand mix concrete, it won't be so bad. You could use a deck paint to give the deck one consistent color and look.
    Just draw straight lines along the cracks and cut on the lines. You can rent a diamond blade concrete saw from a rental place. If there is any part of a crack that is unlevel, and might present a trip hazard, you should cut back a little bit to create a smooth transition.
    For the smaller cracks, you could use sanded tile grout or mortar to fill in the cracks and then paint the deck to get a good overall look.
    Tape some plastic up as a barrier to prevent concrete dust and chips from getting into the pool.
    Support the site
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    On the corner that has separated and seems to be floating away, and not level with the adjoining peice, would it make sense to have that whole corner replaced?
    I just had the sundeck portion and another slab behind my house redone, and there was no reinforcement in the concrete. I have a good cement guy.
    K-2006 Test kit
    Ft Lauderdale, Florida
    1,455
    How old is your pool? There's a possibility that your ground is not compacted well enough. There's also a possibility of a leak in your pool, in that area, eroding the soil below that part of the deck.
    You may want to check with your builder, to see if this is a covered warranty item.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Quote Originally Posted by x2rider
    Yes, if it is substantially unlevel, then removing and repouring the section might be the best way to go. Cut straight lines and remove the bad section. I think that I would avoid trying to remove the concrete from the coping as that might end up causing more problems unless you think that it will come out easily.
    Poolsean make a good point, is there any reason to suspect a leak?
    Support the site
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    I'm not sure how old the pool is, but it has been here a looong time. When we moved in, the liner was faded bad and both corners of the shallow end had holes at the top.
    This pool, and another pool up the block from us were put in at the same time, and not by a builder, but by the owners.
    The house was built in 74, and the pool was either put in shortly after, or early 80's.
    The sundeck next to this piece was really bad cracked (which you can see in the picture), which we had replaced this year, and there was no rebar in it.
    We moved in Nov 08, and put a new liner in spring 09.
    The guy that installed the liner thought we would get maybe anther 10 years out of her before it would have to be redone, or filled in.
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    new liner
    K-2006 Test kit
