Results 1 to 9 of 9
Thread: Intex 2650 sand filter, apparently low flow.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Hello everyone. Here's the deal. All the equipment mentioned here is brand new. Hooked up my Intex 2650 filter to my pool last week, and everything appeared to work fine (other than I didn't backwash enough - that's another story). Finally got around to connecting my heat pump last night, and the outlet flow into the pool appears to be significantly lower. Also the pressure gauge rose from about 6 psi to 11 psi. Backwashed, and same thing. I do have one small leak going from the heater to the SWG but not enough to account for low flow. I don't know how to link to other threads but Osiviper posted awhile back and showed a video of his low flow. Mine is like that or worse. The water being pumped through the heater couldn't have that much negative effect on flow could it?
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    22,550
    Re: Intex 2650 sand filter, apparently low flow.
    It wouldn't be hard to believe that the heater has a restriction of 5 psi.
    You don't say what HP you have so we can't look up the head loss for you.
    Jul 2011
    844
    Sorry, the pump is 0.95 hp.
    Bestway SWG
    22,550
    Sorry I shouldn't have abbreviated. I meant Heat Pump.
    Jul 2011
    844
    LOL.....the heat pump is Aqua Pro Pro500
    Bestway SWG
    22,550
    I can't find anything on the units. The manual doesn't give any specs.
    Jul 2011
    844
    The manual is the absolute pits. I don't think the manual even mentions the 500.
    Bestway SWG
    Jul 2011
    844
    I disconnected the hose from the return inlet to the pool just to see how much flow I'm getting. The pump shoots the water about a foot to a foot and a half out of the hose....that doesn't seem like much flow at all...it's a 2650 gph pump. Can someone with the same filter as me (Intex Sand filter 2650 gph) please let me know about their flow? If my flow isn't proper I want to contact Intex, as it will soon be time to take the pool down and store it for the winter. I'd like to rectify this problem (if it is one) before I set up again next year. Thanks so much everyone for all the great advice I've received on this forum so far.
    Bestway SWG
    Jul 2011
    844
    One bump.
    Bestway SWG
