Results 1 to 9 of 9
Thread: Removing vinyl wrinkling at skimmer.
    Jun 2011
    Northeast Ohio USA
    178
    Background: Neglected pool, new owner.
    Noticed several wrinkles that are likely just to have to be accepted for now, but there is probably the worst wrinkling a few inched below the skimmer (plate?) opening. Plate is held on with 12 screws and I assume nothing else like glue has been used.
    My question then, is it likely worth removing the screws and the skimmer plate and push the excessive liner that is causing wrinkling up into the skimmer opening and then rescrewing the plate (through the new liner surface)? If there is no risk, it would be nice to make the liner less unsightly, but at any risk, it is liking not worth the trouble.
    Thanks.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
    22,553
    Re: Removing vinyl wrinkling at skimmer.
    A picture of the area would help. It could help, but then again, depending on why the wrinkles are there, it could make it worse.
    Jun 2011
    Northeast Ohio USA
    178
    I will post a picture tonight/tomorrow if you'd be so kind to check it out. I can only assume the wrinkles are from the neglect or misuse. The liner is pulling away from the top in several other areas of the pool as if if has expanded and shrunk a few times over its life. I imagine that vinyl where the skimmer is, has been cut to fit the skimmer in and is probably offers a least resisent path when it comes to streching. The depth is around 6 feet at that point, so that is a good amount of weight that has potentially pulled on the liner there.
    The neighbor indicated that the previous owners maintenance plan was to drain and refill when the water got too "bad". I cannot confirm this, but I know they do not own a pool, and the filter waste line runs right along their property line and I can possibly see someone confusing a backwash with draining of the pool.
    Intex SWG
    Jun 2011
    Northeast Ohio USA
    178
    Here is a skimmer picture. The lighting and the fact the pump is running, added with than the less than clear water and my unsteady hand and cheap phone camera, well it is hard to tell the wrinkles. Basically there is a large mostly verticle one on the right and several horizontal ones beneath.
    Worries me that several of the hardware (screws) are rusting, shown here but also on the return eyeballs and the shallow end rings. Is this a sign of poor chemical balance or incorrect hardware?
    [attachment=0:34h8f7j3]skimopen.jpg[/attachment:34h8f7j3]
    Intex SWG
    22,553
    Your rusting is most likely both from chemical balance and material selection. Get some good stainless screws and replace those soon.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I can't see any wrinkles
    A magic eraser may take the rusty color off the return eyeballs.
    Jun 2011
    Northeast Ohio USA
    178
    Thanks BR, I will replace them all. eyeballs need them and the rings (not sure the exact term, but when I says rings they are the little ring connectors where you would connect a rope for dividing the deep and shallow ends) do too. While the screws are out I can try and reduce some of the wrinkling.
    Believe me the wrinkles are there, I felt them before I could ever see them. Had I turned the pump off, they might have been more apparent in the photo, but getting the water clear is of most importance to me. Looking at fixing these other little things helps me remain patient while I "wait" for the water to clear up!!
    I have heard the magic eraser works wonders, but have not found one for sale yet. Sams had a 10 pack, but I did not feel I needed that big a commitment. Wanted to try one before I bought a truckload.
    Also. I considered replacing the screws, and I am glad it was suggested. Also I considered applying something to the ends (glue, vaseline, gasket greese, etc..) to help limit the contact with the water. I can see this being a bad idea if the substance I choose comtaminates the water though. Also it may be totally uneeded should I continue to maintain proper water chemistry. thoughts?
    Thanks again for all the great insights.
    Intex SWG
    22,553
    Use good stainless scrws and you won't have to coat them with anything.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Wrinkles around the skimmer... probably wasn't installed that way. I suspect tri-chlor tabs in the skimmer basket at some point which, when the pump was off, set up a low pH and high chlorine area near the skimmer which can cause fading of the pattern and wrinkling.
    I doubt that you'll be able to work them out but you can pop the faceplate off and work what you can into the skimmer mouth, then replace the faceplate and trim what you worked into the skimmer. This can be done with the water up.
    Luv& Luk
    -Ted
