Results 1 to 10 of 10
Thread: New pool (and owner) - Light question
    Jun 2011
    Northeast Ohio USA
    178
    Been cleaning a neglected pool for over a month now.
    Seems there is a pool light installed. To be accurate, water is still a bit cloudy, so it is hard to be sure there is a light there, but I cannot imagine why there would be a glass enclosure in the wall of the pool, unless it was for a light.
    Question. What steps would one go through to determine how to operate the light?
    The light opening (enclosure) is about 3 feet below the water level.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
    22,553
    Re: New pool (and owner) - Light question
    There should be a junction box behind the light, above the ground. Maybe against a fence or something else. If it doesn't have a switch there, there'll be one either at the sub panel or on a wall somewhere, probably near the rest of the equipment.
    Jun 2011
    Northeast Ohio USA
    178
    Thanks Dave!! There is a box inside the pool out-building the I could not figure what it was for. It has some words (manufactor name, etc) but I cannot remmeber what they are. I will try and get a picture tonight after work. Do not remember seeing a switch on it though., but there are some switches in the out-building.
    To continue my question, not knowing the condition of the pool, but do knowing electricity and water do not mix well, what precautions would I need to take to check this? Also, assumming the bulb needs changed (now or in the future), can this be done underwater? safely?
    Intex SWG
    22,553
    Assuming it was installed correctly in the first place there will be a gfci for it and it's rated to be a swimming pool light.
    There's a provision for removing the light from the niche and there will be enough cable to lay it on the deck so you can work on it.
    Jun 2011
    Northeast Ohio USA
    178
    Now that I think of it, there is a switch on the equipment power pole located by the pump/filter/plumbing. Maybe that is it? The pole has two outlets, one with the switch, and one that connects to an timer. Whenever the switch is turned to the "ON" position, it trips the circuit. Whenever anything (like the pump) that draws a significant load is plugged in, it trips the circuit. Something small, like a radio or circuit tester functions fine. Supposed to have an electrician friend looking at it, but that has not panned out as of yet. I am betting now, there is a good chance that it is all related....
    Intex SWG
    Jun 2011
    Northeast Ohio USA
    178
    Here are some pictures.
    First is the possible junction box.
    Second is the power switch.
    If this is correct, then the next process would be to fix the power pole power??
    [attachment=1:1xy39akj]junction.jpg[/attachment:1xy39akj]
    [attachment=0:1xy39akj]powerpole.jpg[/attachment:1xy39akj]
    Intex SWG
    22,553
    those are definite possibilities for being the light. Have you pulled th top off the j-box to see what's in there?
    Jun 2011
    Northeast Ohio USA
    178
    No, what am I looking for? Maybe I will get a picture of that tonight.
    Intex SWG
    22,553
    There should be just some wires joined together if it's a 120 volt light. If it's a 12 volt there's probably a transformer under there.
    Jun 2011
    Northeast Ohio USA
    178
    Thanks again Dave. I popped the cover, and three wires coming in from both openings. One wire of each are grounded off, and the others are connected with wire nuts. Underside of the plate has more info stamped on it. Part of the stamp read "pool junction" or some verbage as such. Will have to run a trace, to see if it goes over to the power pole switch, but that only makes sense at this point.
    Still concerned as to why the power is not working correctly. Most of the other equipment damage was weather related (freezing), but nor sure how that could explain the light/pole not functioning.
    Intex SWG
