Results 1 to 13 of 13
Thread: Dead roaches and a Gecko in skimmer basket
    Just today i saw some roaches and a gecko inside the Quick skimmer basket. I am confused, Is it still safe to swim in this water ?? Because I don't know for how may days these animal's are in the basket.
    I am confused how do I clean this mess now
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Re: Dead roaches and a Gecko in skimmer basket
    What are your test results? How does your water look?
    I know this question comes up all the time, but they will help us help you.
    If your water chemistry is still good, .5 or less CCs, Free Chlorine levels are at or above minimum for your CYA and your water is clear, you should be fine. If you really wanted to be sure your could try and Overnight Chlorine loss Test. It's not uncommon to find little critters in your skimmers (or pool) even when water chemistry is correct.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Aug 2010
    Boston, MA
    176
    Longer-term, you probably ought to be checking the skimmer every day. Testing and adding chlorine needs to be done every day, too, so it's easy enough to combine them.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    pool chemistry is good, I got water tested from pool supply store.... Psychologically, I am not feeling very comfortable, Really confused
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It's ok as long as the pool chemistry is good. A bigger animal I would be a little concerned. If you think about it, when you swim in a lake or pond or even the ocean it's untreated and the fish defecate in it.
    Quote Originally Posted by bobodaclown
    A bigger anima
    Like what ? I want to prepare myself
    Puffin's Avatar
    Jul 2010
    217
    Honestly, this your pool. The whole point is that it is for your enjoyment. If you're not enjoying the pool, then feel free to do something that will allow you to. What would make you feel more comfortable? If adding some extra chlorine or shocking would make you feel better, then by all means do so. We're just saying, if your chemistry is good and your water is clear you're fine. The chlorine did it job and kept your water safe and sanitary for swimming.
    As far as the critters go, think of it like this. A pool looks like a big watering hole. Those critters don't know or care that is chlorinated, borated, or whatever. They just know its water and they want some, occasionally they fall in and get trapped. When they do they end up in your skimmer or pool bottom. I don't know if you have a dog, but they'll drink out of a pool without a second thought, why would bugs or other critter be different? Same for swimming, after dogs take a swim, the pool is still safe (assuming the chemistry is still good, etc...), same goes for other critters.
    I'd freak out at a rat, a bird, or a squirrel if it had been there a few days.
    Bugs don't count. And geckos and lizards don't have much to them either.
    From time to time I get a huge number of centipedes in the pool. Not squishy so not much of a bother.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    We used to get chipmunks on a regular basis (until they all drowned I guess...). I just would test for CC, there never was any, even if it had disintegrated a little bit
    Just haveta wait for the smell to dissipate, then you're good to go.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No worries there friend. Thats why you have chlorine...enjoy the water! Not much time left now.
    Essential Links:
    Puffin's Avatar
    Jul 2010
    217
    Quote Originally Posted by Melt In The Sun
    Lol, I wish my pool would get rid of my chipmunks. Either they know to stay away, or have figured out how to drink from it and not fall in and get trapped.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    There is a small stream just behind my pool fence that feeds into a wet land area. So I get all kinds of critters in the pool every day. Last night there must have been a mass migration of earth worms because the bottom of the pool was littered with them - dozens and dozens. It's a rare day that I don't find some kind of animal in the skimmer or on the bottom of the pool. I've had turtles as big as dinner plates, bullfrogs, snakes, armadillos, squirrels, lizards, and even a small raccoon (still alive- but weak). About two weeks ago I found four ducks in the pool swimming around enjoying themselves. In the past I've found Canadian geese swimming in the pool and pooping in the water. So a few bugs don't bother me at all - just keep the chlorine levels up.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Aug 2010
    Boston, MA
    176
    Once had a baby chipmunk in the skimmer. My wife was sad since he was cute, but I viewed it as vengeance since his parents eat all my strawberries.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
