Results 1 to 7 of 7
Thread: Edge of inside pool liner corner caving down.
    Around the inside corner near the skimmer and in another spot, I notice the liner caving
    in a bit no leaks, seems the skimmer overflow due to rain eroded the ground under the liner
    I have the thickest liner you could get, its been like that for years, anyone else have that
    problem, if so how did you handle that? Its not effecting the supports or anything like that.
    and I plan on filling and compacting when I need a new liner. any ideas what I can do now
    short of replacing the liner?.
    Gary
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Edge of inside pool liner corner caving down.
    Hi, could you post a picture of the problem?
    Love TFP? Become a
    TFP Supporter!
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    Mine is also like that in about a 10' long stretch right inside the foam cove I have. It's been that way for probably 10 out of it's 16 years & it's caused no problems with the liner so far. I've just kept an eye on it & it's never gotten any worse. It has probably sunk maybe 1/4 - 1/2 inch. Like you, I'll fix that along with re-leveling one side of the pad whenever I replace the liner.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    Quote Originally Posted by ultra800_96
    Yep, that sounds exactly like my problem, I will post pictures later today or tomorrow, I guess we will need ti fill then compact one day
    but I think we both have some sort of grade problem around our pool as well.
    Gary
    Here is a photo taken today, of that, "note the lower center of photo"
    Liner is the thickest they make, and a good thing, was like this for
    about 3 yrs now, what would some of you do about that?. my wife says
    leave it.
    Gary
    Aug 2010
    Pekin, Illinois
    8
    Looks exactly like what I was blameing on mole tunnels as I had several place like that but not at the skimmer area. First one was about 5yrs ago, then another and then another, the first just a round depresion, the others 2 to 4 ft long, maybe 3" wide. Last winter, mid Jan. the liner got brittle enough that it broke through. One day it was normal, 2 or 3 days later I noticed the winter cover stretched tight and clips coming off, looked in the pool. It looked like a giant ice doughnut, a hole down the center and the winter cover was trashed.
    24' round, above ground, 1hp 150# sand filter, live in the middle of corn fields, have well water
    22,549
    I wouldn't worry about it. Fix it when you replace the liner.
