Thread: Chlorine Exposure at Water Park
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I hate it when stuff like this happens.
    20 taken to hospital with symptoms of chlorine exposure at water park in Sacramento, Calif
    http://blogs.sacbee.com/crime/archives/ ... o-hos.html
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Chlorine Exposure at Water Park
    Not enough info in the article obviously to know what happened. Is there any possibility that places like this use gas? If not, how would there be enough exposure to cause problems this severe?
    Essential Links:
    I think many big commercial pools use gas. I don't know about California they are usually the first to adapt new rules.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    Aug 2007
    Eastern Canada
    54
    More: http://today.msnbc.msn.com/id/44158099/ns/travel-news/
    Sounds like they were using gas, and the concentration was too much. A local pool here had a different problem recently, when someone somehow mixed hydrochloric acid (ph reduction), and liquid chlorine in the same container, and generated chlorine gas.
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
