Thread: HB screws
    HB screws
    which screws are best to use on the Hardibacker. the ones i have seem to not go flush w the HB and don't secure well. also what would happen if you don't put tex feet on the island. its by a pool area but don't get much water. aren't the studs galv. which wont rust?
    Jun 2010
    Dripping Springs, TX
    125
    Re: HB screws
    When you buy Hardibacker at one of the big hardware stores, there is a type of screw specifically designed for use with it that is usually sitting close by.
    It looks like a drywall screw, but with coarser threads. They have the fluted shaft and screw in flush with the Hardibacker. The bucket of screws I bought
    came with a square headed drive bit that is specifically for use on these screws.
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    Jan 2011
    Riverside, CA
    352
    Re: HB screws
    You want ones like this:
    http://www.amazon.com/ITW-Brands-23410- ... B000WG0552
    Some of them have a pointed tip, some of them have the self-tapping tip.
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    Re: HB screws
    thanks guys!
