Thread: Blown GFI?? Heavy Rains possibly cause it?
    Jun 2011
    Northern Maryland (near Delaware)
    170
    So we had about 6 inches of rain here in the last few days. Tonight my filter was not running and I noticed my timer was off by 5 hours and powered down. Now I havea protected outdoor outlet with a GFI that tripped? At the time the timer stopped the pump was not on so there should have been no load. Could heavy amounts of moisture cause that? The timer is on a 4x4 and the gfi is about 10-12 feet away where it is partially buried according to code. I have been running the pump for 4 hours and no issues.
    Is this something that could happen with all the rains, I am not sure if it was raining at my home today but near my work about 30 miles away we had heavy lightning.
    As for the Wiring, it was all done by a licensed electrician and up to code, the inside breaker did not go.
    Thanks
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Blown GFI?? Heavy Rains possibly cause it?
    It doesn't take much moisture to trip a GFCI, and it will trip regardless of whether it's loaded or not.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Ditto what he said.
    I had a wet extension cord that I was going to use with my submersible pump once during a rainstorm. Wiped the prongs dry on my pants, plugged it in, bang. Nothing was plugged into the other end yet! They're that fussy.
