Results 1 to 7 of 7
Thread: New here, pool finally clear for the 2nd time this year
    Jul 2011
    S.W. Ontario, Canada
    23
    It was clear when we filled it in June, and its been cloudy until today for most of the summer
    Switched to walmart bought borax and bleach but struggled with white cloudy water that would settle to the bottom
    but constantly get stirred up and seemed to circulate right through the filter and back into the pool.
    Shocked pool, added DE to sand filter, adjusted ph with borax and today the pool is finally clear and 81 deg.
    Looking forward to starting next season clear and sparkly and keeping it that way !
    We were in the pool today quite a bit........... relieved that it was clear
    FC dropped below 1, added walmart bleach to bring it back up to 4
    I finally feel confident that I can maintain the pool for a season
    thanks
    2012 new 15' x 52" round sharkline above ground, DIY installed & BBB maintained. 3/4hp with 19" 150lb sand filter, 4 x 20 sungrabber solar heater. DIY solid piped.
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Re: New here, pool finally clear for the 2nd time this year
    Quote Originally Posted by repsolal
    Oops, had to edit my post because I was going to tell you that you should never let your FC get below your "minimum" target level in relation to CYA, but on a second read of your post I saw that you had a heavy use day (hot weather, full sun, lot's of swimmers = high FC demand) and that's why she dropped out on ya. One way to compensate for times that you know you'll have heavy usage is to dose +1 or +2ppm above your "maximum" target FC the night before. You can safely swim right up to your "Shock" level for your CYA level, if that eases your mind when you overdose. Otherwise, glad to hear you're clear
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    Jul 2011
    23
    Awesome, thanks for the tip as it looks like another pool day tomorrow, slightly warmer than today !
    Next door neighbour has identical pool................ theirs was 73 compared to our 81 ! glad I put the solar panels up
    Jul 2011
    23
    My wife just commented that this year was just like last year as far as the pool getting cloudy..........
    Right after our youngest girls birthday pool party !!! 10 7-8 yr olds in a 15' round intex easy-set
    many of them lathered up by their parents with WAAAAAAAY to much sunscreen.
    And just a few days later the pool turned green and then stayed cloudy for the rest of the summer.
    Luckily this year, I found this board and did some studying....... and the pool is back to being clear.
    Next year I will be much better prepared.
    Had another afternoon of fun in the pool today and added more chlorine to keep things in check.
    Aug 2010
    Central NY
    185
    Now you're getting it!! Pretty easy isn't it? You now know your pool. And once you get to know him / her, it's really easy to keep him / her in line. Wish I could say the same for my wife
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    You might ask at the pool store for a Scumball, or one of its competitors. It floats around and absorbs oils, but not water, so all that lotion ends up there, instead of in your filter.
    Aug 2010
    Central NY
    185
    Quote Originally Posted by Richard320
    Agreed
    I use the "Sunsorb" (a little smiley face that sits in the skimmer) and it, amazingly, does what it is supposed to do. I have seen a decrease in the scumline that used to form in the skimmer from all the sunscreen and sweat. And I don't see a "sheen" on the top of my water either. Charlie ... or otherwise
