Thread: Aquarite. No LED, no GREEN lights, all RED flashing
    I have an Aquarite SWG. The power light is OFF, the LED is blank, but all my red lights are flashing. I know the technician is going to want to sell me a new board. Any hints before I give in?
    Jun 2011
    Northeast Ohio USA
    178
    Re: Aquarite. No LED, no GREEN lights, all RED flashing
    Have no experience with this. Hve never used or seen one. Probably could not recognize one as such, had it been sitting right next to me.
    That said, check http://www.doityourself.com/forum/pools ... tor-2.html - Might have some useful info for you.
    Also, I would suggest checking the users manual. They should include a trouble shooting section. Even if the only offered solution is "replace board", the may offer some keywords in there that you could use to search the net for a workable solution.
    It only makes sense that every component on the board would not fail all at the same time, so a less expensive solution is likely to exist.
    Hope that helps.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
    I meant "No LCD". All the green lights are out and all the reds flash together.
