Become a TFP Supporter Pool School
Results 1 to 2 of 2
Thread: DIG 220 fast declining volts and amps...dead power supply?
  1. Back To Top    #1
    So...I think I've tried everything. New cell, new cord, new fuses, cleaned sensor, etc,.
    On power up, 13 volts/2.4 amps, a couple minutes later, 4 volts/.4 amps, a couple minutes later, 0 volts/.2 amps.
    From what I'm reading...the power supply is dead? Is that the correct conclusion before I order a new power module...which I believe is part # 16084.
    Is it common for these to poop out in 6 years, as that's the age of my current system.
    Appreciate everyone's comments on this board, although I think I've exhausted my options.
    I've seen the 16084 online for $400.00...is that about as good as it gets?
    Thanks!
    Jeff
  2. Back To Top    #2
    Join Date
    Apr 2007
    Location
    Ft Lauderdale, Florida
    Posts
    1,447
    Re: DIG 220 fast declining volts and amps...dead power suppl
    Jeff,
    It is pointing to a failed power module, #16084. Try Josh at Saltpoolguys.com. He is a sponsoring member of TFP and offers discounts to fellow members.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
