Thread: Best way to clean filter cartridges
    Hi all,
    What is the best way to clean a filter that will get it really good and clean? I do the "spray with hose" method but that seems to buy me less than a week. It is lowering the flow rate which causes the heater to not run. I searched a little and see some reccomending dishwasher soap soaking, and I think in the past I remember a commercial cleaning solution. So how can I get it really clean? Thanks.
    South Central NJ
    3,192
    Re: Best way to clean filter cartridges
    Soak them overnight in either TSP or cheap powdered dishwasher detergent. This will degrease them. If that doesn't do it, then an acid bath is called for due to scale. (4 parts water - 1 part Muriatic)
    Scott
    Owner of - PoolGuyNJ LLC
    22,553
    Which filter do you have?
    How old are your cartridge(s)?
    Once they get so old they clog up pretty tight and cleaning won't clear them. Try Scotts suggestion and if that doesn't work it may be time for new ones.
    Not sure which ones I have, they're big and round... Anywsay i have two filters because the pool guy used last year included it in the closing process. But even that one is giving issues. Is it possible we have a water problem that is causing them to clog? Last time the water wastested the pH was a little low, and I stick to a regimen of bleach and cleaning, so the water is usually nice and clear.
    22,553
    I suspect that Scotts suggested cleaning will take care of things.
