Results 1 to 9 of 9
Thread: izonator for the pool
    hello new friends !!!
    i'm new here so i don't know if here is the right place to post this question...
    i have clorine pool and i want to change it to non chlorine pool , on the web i saw:
    1. carefree
    2.ecosmart
    3. pristine blue
    Is this stuff really warks or is it just waste of money ?
    do i need anyway to do chlorine shock form time to time ?
    is anyone can recommend one of the system from his/her excperince ?
    Intex 16x4 round AG 6000gal, Hayward 1hp power-flo pump, SwimPro sw256t sand filter, Secondary Hayward c500 star clear filter (cartridge only in after shocking to catch the little stuff). BBB Rookie.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: izonator for the pool
    Hi, welcome to TFP! We have many posters who have used such systems in the past and the vast majority of them where unhappy with the results. Type any of those 3 systems in the google search at the bottom left of this page and it will pull up plenty of threads for you to review.
    The bottom line is all alternative pool sanitation systems require at least a small amount of chlorine be used for sanitation. All pools need chlorine, bromine, or biguanide for sanitation.
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    Central Califorina
    208
    All of those systems have problems associated with them. None are EPA approved sanitizers without the addition of chlorine. They are all very expensive to maintain. The sales people of these systems will enjoy the commission more than you will enjoy their use.
    What is your reason for wanting to go chlorine free??? Many problems associated with chlorine pools are not due to chlorine but improper maintance/testing of the water balance of the pool.
    If you let us know what your issues are we can likely help. There are ways to maintain a lower chlorine level safely such as a salt water chlorine generator. Although these systems can take around $1000 to set up in the long run it would be much cheaper than any of the above systems.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    my main problem is alleges (greens one) , i put chlorine in the skimmers but on the floor of the pool and in the corners alleges divelopt
    i put dust chlorine in the place of the alleges every week, it last for 4-7 day and come back agin
    my pool ph 7.4-7.6, i don't know the other level of alkaline ext , this is my first problem also i want less work at the maintanice,
    my pool is about 11,000 gallons
    May 2011
    Clearwater, FL.
    446
    Read up in the pool school link at top of page, get a good test kit, (I would get the TF-100 ) post your pool water spec's here and we can help with your water balance.
    You might have a CYA level off the charts and thus a problem with not enough chlorine to do the job of keeping the algae away.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Mar 2007
    San Rafael, CA USA
    12,082
    It sounds like you may be using Trichlor pucks/tabs and putting them in the skimmer. If that is the case, that is a bad thing to do because they are very acidic. They also build up Cyanuric Acid (CYA) over time which makes chlorine less effective and would then let algae be able to grow faster than chlorine can kill it. It is important to maintain an appropriately high Free Chlorine (FC) level relative to the CYA level. Read the Pool School as suggested. We can most certainly help you keep your pool algae-free using chlorine alone as that is what tens of thousands of pool owners are doing on this and some other pool forums without the need for any algaecides, clarifiers, floculants, enzymes, or weekly shocking.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    What Chemgeek said!
    My pool is crystal-clear and sparkles. No algae anywhere. All I've ever added to the pool is water, bleach, muriatic acid, and a few trichlor pucks to replenish CYA lost to pumpouts. My equipment consists of a pump, a filter, and a heater. No clarifiers, flocculants, enzymes, ionizers, or mysterious snake oils needed. Just a few minutes every day or two with a decent test kit.
    Jul 2011
    Central Califorina
    208
    Quote Originally Posted by orca
    Yes. Test results followed by a proper shock process or partial drain/refill depending upon your CYA level will clear your pool.
    If you are looking for less work and maintanence then a SWCG would be a good investment. Your pool is much larger than mine but still relativly small. There are people on this site that use the above ground pool Intex SWCG for an inground pool of your size. Although it is not properly electrically bonded it is very cheap and simple to install, (on sale at walmart.com for $100 now).
    This would be cheaper than an ionizer and much more effective. I run mine at night when nobody is in the pool. I keep a minimum FC level of 5 ppm with 80 PPM CYA and the water is crystal clear. I test the water ballance 3 times a week and it is always spot on.
    First things first. Get a good test kit and read, read, read pool school. We are here to help.
    Taylor K-2006
    Thanx you all ,you really cheer me up
    How can I get a good test kit ? I have one that measure only ph & chlorine level
    I'm from Israel so if you know a place that send international it will be helpful
    Sorry if my English not good
    My pool is inground concert with glass mozaic
    Thanx again
