Thread: another CSI question
    I have read through pool school and have been using TFP suggestions for about 2 weeks. the pool has never looked better.
    I have a new (built fall '10, started up spring '11) plaster, SWG pool.
    What would be an ideal CSI to aim for?
    30000 gallon inground gunite pool
    Intelliflo ic-60 SWG, pentair tagelus sand filter, 1.5 hp whisperflo pump, tf 100 test kit,
    2 kids(tl), 1 mini-dachshund/lab mix(t),
    Central Illinois
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: another CSI question
    Quote Originally Posted by tltmom
    Same as everyone else: 0 +/-.6
    Zero is neutral, positive numbers mean it is likely to deposit scale, negative numbers mean it will leach Calcium from the walls. Anything within the +/- .6 range will be fine. Don't obsess on CSI, worry about FC and pH. But look at the CSI and if it starts creeping to the limits, then adjust things.
    thanks!
    I knew the +/- .6 but thought I had read somewhere that plaster pools needed a csi in a smaller range of -.1 to -.2.
    glad I don't have to worry about it.
    Central Illinois
