Results 1 to 8 of 8
Thread: Heater doesn't ignite
    Aug 2011
    Whittier,Ca
    4
    Turn heater on you can hear blower but it doesn't ignite?How do I test igniter?
    pool size 15X30 Filters:Cartridge Aboveground Plaster,Pentair Minimax NT Low NOx Series Heater
    South Central NJ
    3,192
    Re: Heater doesn't ignite
    How many ohms across the igniter?
    Specify if it's hot or cold when testing.
    Other possibles are the fan isn't spinning fast enough and the vacuum switch.
    Scott
    Owner of - PoolGuyNJ LLC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by glsk
    Is this a sudden, recent development? Or is this the first time you've tried the heater?
    I know my heater blows a good long time - long enough to start wondering if something died - before it fires. There is some sort of air pressure switch that can get clogged with spider webs if it doesn't get used much.
    Is the heater giving any error codes?
    Support the site
    Aug 2011
    Whittier,Ca
    4
    Quote Originally Posted by Richard320
    Where is the pressure switch? We use the spa quite a bit this is all of a sudden.Thanks for the help
    Aug 2011
    Whittier,Ca
    4
    Quote Originally Posted by JamesW
    How do I check for codes?
    Aug 2011
    Whittier,Ca
    4
    Quote Originally Posted by PoolGuyNJ
    Scott
    How do I test igniter? This happen all of a sudden The heater worked a week ago?
    Richard320's Avatar
    Jan 2010
    19,071
    Best bet is to google your heater make and model and see if you can't find a manual for it online. The parts exploded view will show you where things are and what they ought to look like.
