Thread: Wiring a two speed Hayward super with Aquarite
    First the normal...love the site and I have found a ton of good info..I searched but cannot find a specific answer to this question.
    I have a two speed hayward pump with the switch on the back cover. I also have the Hayward Aquarite SWG plus that can control both speeds of the pump.
    I currently have it wired just running the switch to control the two speeds, but as i add stuff to my SWG controller (low voltage lights etc) I want to change the wiring at the pump to take advantage of the controllers ability to switch the pump from low to high.
    My question is "How do I do that?"
    My controller basically shows four feeds coming from it when runing a two speed pump (from two different control relays in the system) but how do I "remove" the switch.
    There is a white wire going from the switch to the motor, and a yellow and black wire going from the switch to the "junction" where the pump recieves it's feed from the panel/controller.
    If you need pics let me know I can snap a couple today
    16x32 In ground
    Hayward 2 Speed pump
    500lb Hayward Sand Filter
    Aquaplus SWG
    Owner built
    Pool Chemistry Not available yet
    South Central NJ
    3,192
    Re: Wiring a two speed Hayward super with Aquarite
    You will need a 2 speed relay. In the controller, the 1st relay and 2nd are removed. The 2 speed relay goes where 1st one was. The controller needs to be told it's a two speed in it programming and when to use each speed.
    The switch in the pump will be disconnected and the power leads from the relay's load sides will be connected there the switch leads were.
    Scott
    Owner of - PoolGuyNJ LLC
    I have the two speed relay in the Aquarite and it is very easy to set it up to run the two speed....my question is about wiring the motor itself. How do I wire it so the controller takes the place of the switch?
    16x32 In ground
    Aquaplus SWG
    Owner built
    South Central NJ
    3,192
    Open the access port, find the wires for each speed. The diagram should be on the motor.
    Scott
    The diagram is only for single 220V feed to the motor because the switch is on the back of the end cover. I need to remove that switch and wire the pump so the SWG can control the speeds.
    16x32 In ground
    Aquaplus SWG
    Owner built
    South Central NJ
    3,192
    The diagram shows where the switch sends power. Obviously, there will be 5 wires from the controller if you have 220 volt service, 2 for High, 2 for low and a ground. If it's 120 volt service (doubtful), then its two hots, a common, and ground.
    What was connected to the switch is moot since it's being disconnected from the circuit.
    Scott
