Thread: Spa frog cartridge the same as the bromine tablets?
    Aug 2010
    Columbia, SC
    96
    I purchased a spa last year and I was given the Spa Frog system with it. In looking for a good deal I ordered a case of cartridges for it. Now that I am learning that it is not the best, I was curious if I can continue to use my supply to work as a bromine floater? Is it the same as bromine tabs? Should I use the mineral cartridge or just the bromine? Or throw it all away?
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    Aug 2010
    Columbia, SC
    96
    Re: How do I use Bromine in my spa (or pool)?
    Is the bromine in the spa frog cartridge the same as the bromine tablets for a floater?
