Results 1 to 9 of 9
Thread: First time to hard plumb...a fountain is in the makes (pics)
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Been floating around here a few days and first thing I saw was people hard plumbing there AGP's and the fountains to cool the water down. Here in Shreveport, Louisiana we have had 41 days over 100. Its a record for us. Needless to say, the water is like a sauna most of the time. I just got this pool a month ago but have had trouble with the fittings leaking since install. I started the hard plumb and fountain setup tonight but am missing one piece to keep me from finishing. Plus I have one small drip right before the pipe goes into the wall. I wish I could just silicone the outside of the joint?! Don't know if that will work or if I should just redo that section.
    Anyway, if you have any comments please share. Thanks.
    22,542
    Re: First time to hard plumb...a fountain is in the makes (p
    If it's the threads leaking you can unscrew it and silicone it and it'll seal, otherwise you'll have to redo it. You might get some glue to wick in the joint but that doesn't usually work.
    May 2009
    Youngsville NC
    395
    Rather than silicone - I'd re-do your teflon tape first. Then if you can't get a good seal - goto the silicone
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That looks great! Any plans to hard pipe the vacuum side? That side really benefits from hard plumbing (less occurance of air in leaf basket, less head, less chance of a leak), though yours is really short. I agree with the teflon comment, it is easier to get apart when you need too.
    I your concern of breaking that connection is loosing pool water, pull you eyeball ring and put a stopper in it's place while repairing the joint. People have also used a bowl over the whole fitting.
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Got the stopper in there this morning and took out the one section. Put more tape on the threaded section and coated my leaky part with pvc glue. let it dry in the sun for an hour. put it back on and i have the slightest drip from the threaded section. it takes about 10 minutes for it to form a drip. I'll probably live with it for now. I like being able to unscrew the section when the time comes to close the pool.
    Linen, I plan on hard plumbing the vacuum side this week. Just need to make a run back to Lowes!
    For my first time to work with pvc i was pretty excited how it turned out! will post pics when I finish the fountain.
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Got the leaks fixed and finished my sprinkler pipes. Kinda rushed the drilling because I had people in the pool and was ready to get it up and going! But it turned out pretty good. I can shoot it short or far depending on what I want.
    Thanks to the members before me who put up pics! Helped me a ton!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Nice job...doesn't looked rushed to me...but it sure looks fun to swim under!
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Thanks! Trying to think of something else fun to do with pvc haha!
    May 2011
    Mobile, AL
    19
    Awesome! I will have to put this on my husband's honey do list ha ha!
    Kristyn
    8100 Gal 12X20 vinyl IG pool. Hayward H200 heater, super pump and Pro Grid DE3620 Filter.TF100 test kit
