Thread: Inground Saltwater Pool Anchor Replacement
    I need to replace the anchors for my interfab basketball net. The old anchors the builder put in were aluminum and over time one became locked up on one of the posts. I used rotary hammer to get the old anchors out and actually cut the old anchor off the basketball frame post.
    With a salt water system, what material is recommended for the replacement anchors (bronze, aluminum, fiberglass, etc...) and what type of concrete is recommended?
    Thanks, Andy
    South Central NJ
    3,192
    Re: Inground Saltwater Pool Anchor Replacement
    I'd use a Saftron plastic set in a 6" diameter hole with regular bagged mix.
    Scott
    Owner of - PoolGuyNJ LLC
