Thread: pH, TA, Bromine reading in new start spa
    Aug 2010
    Columbia, SC
    96
    I just refilled my spa and started the testing procedure to balance the water. Fought with a high pH and low TA situation for a while. Is there a trick to get this situation under control? I just about have it after multiple dry acid and baking soda additions.
    Then before adding anything I thought I would test the bromine/chlorine reading for fun. I had detectable levels prior to adding anything. I assume chlorine in the city water? THen I added a capful of MPS and now i have 2ppm detectedwith oto, 1 ppm detected with DPD, and 4ppm with the FAS-DPD test...
    Is this typical? I still have ha hard time grasping the bromine residual and MPS balance issue.
    Thanks!
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: pH, TA, Bromine reading in new start spa
    MPS measures as CC in the DPD test and as FC in the FAS-DPD test (not sure about OTO, but it seems to at least get partly measured there as well). You can get the Taylor K-2042 to remove interference from the MPS.
    Is this spa on chlorine or bromine? Have you added any sodium bromide?
    Support the site
    Aug 2010
    Columbia, SC
    96
    The spa is bromine but this was on a fresh fill prior to any addition of bromine.
