Thread: Air in the system
    Jul 2011
    Austin, Texas
    78
    Air in the system
    I'm looking for ideas on the "not as likely" reasons. This started about 3 weeks ago. No significant changes to the pool mechanics were made. Here is what I have tried so far:
    • 1. Backwashed filter thoroughly and recharged DE. Pressure is good at 20 PSI which is 2lb above fresh full disassembly and clean PSI
      2. Thoroughly cleaned the pump strainer cover, gasket, regreased etc.
      3. Checked for cracks in the cover and pump housing - NONE
      4. Tighten pump drain plug and see no evidence of leakage.
      5. Wrapped the inlet pipe connection with rubberized waterproof tape to ensure seal. The connection was old looking and I thought this was it... but alas, no difference
      6. Individually turned off each skimmer, main drain, spa drain to see if I could isolate air leak but no luck. It makes no difference.
    I'm at a loss. I have NOT tried running a water hose over the short section from 3-way to pump. I guess that's next unless the TFP community gives me any better suggestions. Do you think the Jandy valve could be the culprit?
    30K IG, Plaster with spillover spa, 9 ft deep end with spring base diving board
    48sqft DE Filter, 3HP VS motor, Hayward SPII, Raypak RP2100 Propane heater
    AutoPilot Pool Pilot Digital with SC-60 and pump relay (220v)
    Polaris 280. Pentiar Booster Pump, TF-100 Test Kit, Speed Stir
    Austin, Texas (It's hot)
    22,551
    Re: Air in the system
    I could be several places in the plumbing in the picture. It certainly could be the Jandy, in fact I'd run water over it first. Or just go ahead and take the top off and inspect it.
